18 years agohelp:uart error
hi, i used the uart correctly before, but when i added a function in the uart interrupt function, it can receive the data only once, receiveed another data, the program run out. why?
18 years agoFair enough. Well there's nothing intrinsically wrong with calling a function from within an ISR. The most likely problem is that you are using a HAL function call which relies on interrupts being enabled.
