18 years agohelp:about por by fpga-self
hi, sorry for my poor english. when we want to reconfigure the fpga using as model, we need a power-up, or a low to high jump of nconfig pin. now if the fpga can achieve the effects like a...
18 years agoYou should check the suggested trivial open drain method. We can continue the discussion if it doesn't work.
The Remote Update IP comes into play if alternative configurations (e. g. a factory or fall-back and a user configuration) are needed. Cause Cyclone 1 doesn't support a selection of multiple configurations from a configuration image (it misses the selection inputs), the MegaFunction is useless here.
