16 years agoHelp with verilog code, calculator
Hello, i don't know if this is the correct place to put this post, if not, please move it! I'm a newbie when it comes to programming in Verilog, I'm currently working on a final project for my ...
16 years agoOh thanks, i clicked on the link and i read and tried to get it but unfortunately i didn't understand much.
Can you help me with that part of the code? I would really appreciate it if you did! Lets say i would take number 4 and 5 ... multiply the 4 with 10.. then put 40+5 into a integer called number1 then i put only the number 2 into the second integer called number2 .. how do i write the code to get the rest from the division 45/2 ? (which is 0.5) using that mega function? plus, do i need to add extra things in the program for this mega function to work? Again, Thanks for your time! //Reckan
