16 years agoHelp with verilog code, calculator
Hello, i don't know if this is the correct place to put this post, if not, please move it! I'm a newbie when it comes to programming in Verilog, I'm currently working on a final project for my ...
16 years agoHi Reckan,
Welcome to Altera forum. It's difficult to handle floating point numbers, so I think you can use the Altera's IP mega function lpm_divide (http://quartushelp.altera.com/9.1/master.htm#mergedprojects/hdl/mega/mega_file_lpm_divide.htm?gsa_pos=1&wt.oss_r=1&wt.oss=lpm_divide). You can take the remaining part and use it with integer operations. You can simply multiply the number by 10 or 100 (depending on how many digits you want after the whole part) and then add the remaining part. Best regards, VT
