15 years agoHelp with Signal Tap II
Hi, i am running some tests with a designe, but as it is a prototype there are a few jump wires between two boards. I am trying to take a look at a signal with logic tap II and USB Blaster on a Cyclo...
15 years agoOk thank you for the explanation. I managed to solve the problem with a weak pullup on a enable pin, so if the enable pin goes to 0, for sure the microcontroller will be operational so i wont have any floating pin.
Thank you!
