15 years agoHelp with Signal Tap II
Hi, i am running some tests with a designe, but as it is a prototype there are a few jump wires between two boards. I am trying to take a look at a signal with logic tap II and USB Blaster on a Cyclo...
15 years agoYou may also trigger the inputs on touch. They are apparently floating until they are driven by external source. You can use weak pullup as a remedy.
