18 years agohelp with clock
I need to run a clock signal through a regular IO and then lock on to it using a PLL. Quartus doesn''t seem to like me doing this. Has anyone done this before and if so, how did you get it to work...
18 years agoApparently you are running into this restriction in the footnotes for figures 1-3 and 1-7 in the Stratix II handbook Volume 2: "An internally generated global signal cannot drive the PLL."
Given what the device does support, I expect that what you want to do is possible in hardware. You might be able to get a Quartus INI variable to allow it (with no guarantees about jitter or whether the PLL will lock). You need to file an SR through MySupport to request that.
