15 years agohelp to rectify the error
architecture Behavioral of hamming is
signal f : integer ; signal i : real := 0.0 ; signal Pi : real := 3.14159; begin f <= (passband)+ (transition_width /2) ; l1 : for i in (N-1)/2 downto (1-N)/2 generate w <= 0.54 + ( 0.46 *(COS((2*i*Pi)/(N-1)))); end generate ; l2 : for i in (N-1)/2 downto (1-N)/2 generate x<= 2*f*(SIN (i*wc)/i*Pi); end generate ; l3 : for i in (N-1)/2 downto (1-N)/2 generate h <= w and x ; end generate ; end Behavioral; ERRORS : "C:/.Xilinx/gateor/hamming.vhd" Line 51. * can not have such operands in this context. ERROR:HDLParsers:808 - "C:/.Xilinx/gateor/hamming.vhd" Line 54. * can not have such operands in this context. I AM USING use IEEE.MATH_REAL.ALL; use IEEE.NUMERIC_STD.ALL;4 Replies
and it could be a good idea to have a look at cosine/sine generation algorithms, or use a table to store precalculated values.
dont use real type? use fixed point instead.
sir,i am constructing hamming window for speech recognition system.can plz suggest me now anything on my program.
what are you compiling this code in? If it's a synthesizer then it won't work, reals aren't synthesizable.
