18 years agohelp: the problem of nios ii command shell
hi, i used the command of nios ii command shell ---elf2flash, "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x01000000 --end=0x17fffff --reset=01000000 --input="my1.elf" --output="flash1.flash" --bo...
18 years agoInterestingly, someone has posted almost the exact same problem on the NIOS forum, except that the file is located on the D: drive.
