18 years agohelp: the problem of nios ii command shell
hi, i used the command of nios ii command shell ---elf2flash, "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x01000000 --end=0x17fffff --reset=01000000 --input="my1.elf" --output="flash1.flash" --bo...
18 years agoI can not tell you exactly why but I can give you hints and tips. The more information we have the better the quality of our help will be.
Are you using the epcs controller or the flash controller? To which controller have you set the Nios 2 reset vector? If you are using the epcs controller try the flash programmer GUI in Nios 2 IDE. Did you try using only '/' in your path? Did you try looking in the debug or release folder of your software project to see if you found any boot flash files. Since you have an old version of Nios 2 IDE you might not find it there though. //Ola
