15 years agoHelp: SRAM DE2 Board
hello, i am having problem writing and reading into SRAM on de2 board. the model of my SRAM is IS61LV25616 512KB. following is part of my code: --- Quote Start --- # define loop 125000 ...
15 years agoYou can use the memory test template to check the SRAM and your timing parameters.
Are you sure the SRAM isn't used for anything else? Program code, heap/stack memory, or exceptions?
