14 years agoHelp. Sdr Sdram controller
Hi, I'm pretty new in the vhdl language, and I have a big problem with the sdr sdram controller. Can i use a sopc builder's sdram controller without a nios II processor? Which MM-Avalon Shoul...
14 years agoThere's absolutely no problem in using a sdram controller or any other MM slave device in sopc builder without a Nios processor.
But you are required to have an alternate Avalon MM master. This could be a dma engine (but you are still supposed to supply a master for the control port) or a bridge driven by a non-Avalon external master.
