15 years ago[Help on VHDL] FATAL ERROR while loading design
Hi guys, I've just started learning VHDL for a week on my own so i'm still very new to it. I'm doing a practice on implementing a 4-bit parallel-out serial shift register.. My codings can be complied...
15 years agoyour test bench is a good starting point. It is usually easier to generate the clock in a separate process and concentrate on the other signals in your main test bench process.
What are the differences between what you want and what you get?
