15 years ago[Help on VHDL] FATAL ERROR while loading design
Hi guys, I've just started learning VHDL for a week on my own so i'm still very new to it. I'm doing a practice on implementing a 4-bit parallel-out serial shift register.. My codings can be complied...
15 years agoTry
din: in std_logic_vector(3 downto 0); -- data in The error message tells you that your port din doesn't have a defined size. AFAIK unconstrained arrays can't be used on ports.
