15 years agoHelp needed! thx
hello, when i run my program as NiosII hardware in nios2 ide, the following error msg appeared: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Readi...
15 years agoI double checked pin assignments, sdram controller config and still my sdram doesn't work. I can attach some screenshots. Could someone looked at it then?
