15 years agoHelp needed! thx
hello, when i run my program as NiosII hardware in nios2 ide, the following error msg appeared: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Readi...
15 years ago --- Quote Start --- Where was the problem, cause I've got the same situation? --- Quote End --- I think, you should check the pin assignments of SDRAM. Were all the pins are located correctly?You should also check that some output pins of your SDRAM may be bidirectional.
