15 years agoHelp needed! thx
hello, when i run my program as NiosII hardware in nios2 ide, the following error msg appeared: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Readi...
15 years agoIs it a custom FPGA project? Try to run a memory test from on-chip memory and test the sdram.
You probably have a timing problem. Check the settings in the memory controller, that your clocks are properly declared in Timequest, that your input/outputs are properly constrained, that your design meet the timing requirements and that you provide a clock with the correct phase shift to the sdram.
