17 years agoHelp needed: large onchip memory on 3c120 board
Hi, I am working on a video processing application on altera 3c120 board. the video pipeline accesses ddr2_bottom memory. and thus t is isolated from niosII and other two SGDMA accesses...
17 years agoWhen you instantiate any core (i.e. NiosII with cache) which uses onchip memory as a buffer or fifo, it acquires onchip memory in single/multiple M9K based on design implementation.
So lets take an example you need 1 kbits of onchip memory. Compiler will assign one full M9K block even if your usage is 1 kbits. So memory usage you see on result may be less but how much M9K block it used is important. I hope this has clarified your doubt.
