18 years agoHELP: How to Use sopc to W/R two FLASH ?
In my work, I plan to use two flash to store the data sheet, which are two seperate data sheet. In the same clock cycle, FPGA can get the two flash data. Actually speaking, the data sheet are all 16b...
18 years agoAha. It is in this wise.Thank you very much, Maga.
I use Quartus 5.1 and find there is no "Program a file into flash memory" choice menus in Flash Programmer with Nios2 . It means that I have no way to write my " .bin" to flash , what about other edition of Quartus? If I go on work with 5.1 edition , I can write my data sheet with MCU(Single Chip Micyoco)。I think there are two ways to read the data in the flash , one is to read them with a driver designed with VHDL or verilog, the other one is to use Nios2. Does anyone have the related experience ? I mean using the two ways to read the data from flash. Could someone attch some metierials or programs? Thanks very much. --Yang
