18 years agoHELP: How to Use sopc to W/R two FLASH ?
In my work, I plan to use two flash to store the data sheet, which are two seperate data sheet. In the same clock cycle, FPGA can get the two flash data. Actually speaking, the data sheet are all 16b...
18 years agoso, NIOS support 32 bit of FLASH, you just using all of the same signal at the FLASH, excpte data port.
eg. FLASH_1 for data[15..0], FLASH_2 for data[31..16]
