18 years agoHELP: How to Use sopc to W/R two FLASH ?
In my work, I plan to use two flash to store the data sheet, which are two seperate data sheet. In the same clock cycle, FPGA can get the two flash data. Actually speaking, the data sheet are all 16b...
18 years agoThe Nios CPU works according to my programm , can I control the two flash at the same time? I mean using the same data addres to read the both flash , so I can get 32 bits data-width at the same clock cycle. If it can't work , do I have to make the two flash data addres seperately?
Could you explain more about it, mirimon? Thanks very much!
