13 years agoHELP, how to store data into the memory(example flash or any memory on my fpga
Topic: HELP, how to store data into the memory(example flashor any memory on my fpga dev kit) and read out the data when needed Example my is data is 4 bit 0110, 0111,0000…… Anyone can advis...
13 years agoMaybe you should watch some web seminars from altera to understand all this things...
FYI: QuartusII is the Software where you can Write your own VHDL/Verilog/etc Code and where you synthesise this code to get this HW-Description to your FPGA. NIOSII is a Softcoreprocessor which acts like a "normal" Microprocessor but which is in the FPGA if you put him there...
