17 years agoHelp for storing nios II software and fpga config in flash
Hi, I need some help about storing fpga configuration and nios software in a extern flash. I'm using pci dev kit from altera which has a stratix II gx, a 512 Mb CFI flash and a epm570 with...
14 years agoHi guys,
I need help with flash programming for a problem very similar to yours! Like you, I can program flash converting .sof to .pof and load NiosII software via jtag after each start up, or I can program flash with Flash Programmer with .elf and load configuration hardware via jtag. In these cases the system work. But using Flash Programmer in NiosII IDE, I can't download correctly configuration hardware (.sof), so I can download a complete system (.sof+.elf) working at the power-up. In the forum I read a lot of discussions over this problem, but all of them solved the problem with a patch of EDS 9.1 SP1, but I'm using Quartus 10.1 and Nios IDE 10.1 that solved this problem. Someone can help me?
