17 years agoHelp for storing nios II software and fpga config in flash
Hi, I need some help about storing fpga configuration and nios software in a extern flash. I'm using pci dev kit from altera which has a stratix II gx, a 512 Mb CFI flash and a epm570 with...
17 years agoDid you mean FPGA configuration ? Yes, it's the good one.
If I program flash with a pof file (obtained from convert programming file in quartus), the good fpga configuration is running but I need to load nios software via jtag after each start up. But with flash programmer in nios ide, I can't download correctly configuration and software because of this cfi table not found error.
