17 years agoHelp for storing nios II software and fpga config in flash
Hi, I need some help about storing fpga configuration and nios software in a extern flash. I'm using pci dev kit from altera which has a stratix II gx, a 512 Mb CFI flash and a epm570 with...
17 years agoanother question that is not clear to me
does your fpga successfully load your fpga image ? just to make shure that it is your fpga systen that is running and not the one already stored on that board. maybe you can check via sysid
