19 years agoHelp for Jtag Programming
I am completely new with my MAX II CPLD (and also a new engineer) and I want to use the Jtag interface with my 8051 microcontroller (without Jtag interface). I’m confused about what to do as the firs...
18 years agoHello,
I think you will have a lot of fun, specially if you are using a MAX II CPLD, the distributor told us that it not compatible for using the JBC Player which allows to generate the code for programming the device. For us it was a problem and finally we gave up. If it is not your case try to read the information about the JBC 1.1 Player I think the other versions are not supported by our 8051. Any way, Good Luck and please, if you get it write some letters here.
