15 years agoHelp: Altera DE2 Board
Hello, after i program the board using Programmer from QII, suppose all the lights including LED and 7-seg-display should be off but somehow, there is a light at the 7-seg-display on board. pls see a...
15 years agoAre all the signals in your design assigned to a pin?
Usually this happens when you have an unassigned signal and the router connects it to a different pin every time you recompile the design.
