15 years agoHelp: Altera DE2 Board
Hello, after i program the board using Programmer from QII, suppose all the lights including LED and 7-seg-display should be off but somehow, there is a light at the 7-seg-display on board. pls see a...
15 years agoTwo possibilities:
- the signals driving the 7seg behave differently because of you code changes; is the 7seg is supposed to display anything or is hardwired off? - you changed something in the pin assignments and the 7seg signals are no more connected to the right pins I don't have the DE2 board schematics on my current location, so I can't tell you which pin drives that specific segment.
