18 years agohelp: about flash programming
hi,when i do my flash programming,it shows the following tips: -------------------------------------------------------------------# !/bin/sh# # This file was automatically generated by the Nio...
18 years ago --- Quote Start --- there is no test or stander project about CFI offered with DE1 kits --- Quote End --- Are you sure? I downloaded the latest kit (v7) from here (http://www.terasic.com/downloads/cd-rom/de1/), and it appears to have a DE1_NIOS demonstration that has it's Reset Address in the CFI flash. I don't have the DE1 to test this design, but it sure looks like a good start to me. At the very least, you should give it a try and contact Altera (Terasic really) if you have further issues. Until you can successfully access your CFI flash, you're dead in the water. Cheers, - Ura
