18 years agohelp: about flash programming
hi,when i do my flash programming,it shows the following tips: -------------------------------------------------------------------# !/bin/sh# # This file was automatically generated by the Nio...
18 years agoCan you get the flash to program by using one of the standard projects supplied with the DE1 kit? If you're using your own project, make sure that all the signals to the flash are correctly connected. Is the flash reset line held high?
