18 years agohelp: about flash programming
hi,when i do my flash programming,it shows the following tips: -------------------------------------------------------------------# !/bin/sh# # This file was automatically generated by the Nio...
18 years agolw,
Further to Ketan's suggestions: You ask what the CFI table is. This is a table which is built-in to CFI compliant flash devices. If it can't be found, it suggests the flash in non-compliant (unlikely) or there's a problem with your hardware setup. As well as reading the Altera Flash Programmer manual, I'd try searching for 'CFI' or 'flash programmer' on this forum and the NIOS forum, where it's been discussed on several occasions.
