17 years ago
Having Trouble Starting TSE MAC
When my program NIOS IDE is starting and Ethernet port are connnected, I've had this error.
I'm using Cyclone III embedded evaluation kit (neek board)
I've configured TSE MAC as GMII interface and Small MAC 10/100
Your Ethernet MAC address is 00:07:ed:ff:76:2b
prepped 1 interface, initializing...
 Error opening TX SGDMA
init error -22 on net
Any idea??
Thanks in advance!!
    Dear pals,
    The problem were fixed when I put the next name to the components
    'descriptor_memory' to the on chip memory.
    i hope this help you
    David,
    Did you solve your problem?
    Have you succeed to make a TSE Small AMC working with Linux/MMU?
    To Bertronicom,
    Could you please us know which component's name you have made changes?
    Thank you,
    Caridee
    @bertronicom: i am facing the same problem...hixxx can you share me your project (or exactly name what you changed in your SOPC) ?
    thank you very much!
    my mail is [email protected]
    Very old thread but I am facing the same issue and have not seen a fix.
    I have a working example for one board and have copied their device names exactly and cannot get it to work in my board.
    Any suggestions?
    Thanks, I've changed some names in SOPC BUILDER and now it works fine!!!!
    The configuration looks ok...
    Can you run the software in a debugger, put a breakpoint just before the TX SGDMA init and see what happens? Check if the open call returns any error code.
    I've used the same name assigned in a reference design I've seen. You can see in the pic attached.
    Do you have the two sgdma components in your design and do they have the correct name?
