14 years agoHardware primitives giving odd behavior
I am a student just starting with Verilog and am trying to create a module to take all the numbers between 0 and 63 and then modulo them by three and five. I am trying to do it with a pair of ...
14 years agoRealized that I should just package the outputs in text files, also wanted to give the tables for the different modulos I have tried. Have done 2/3/4/5/10 now, and only 3 works.
Things I have tried as well: using only one primitive in the top level, separate inputs for the different primitives, changing the amount of time in the test bench, and re-writing the entire truth table. I get the same wrong outputs on every time regardless of what I do.
