18 years agoGPIO to memory to Ethernet
Hi all, we are research grad students trying to figure out how to get information from the DE2 board's GPIO i/o connectors and store it in the DE2's internal memory. The GPIO connector will recieve a...
18 years agoYou have a long road ahead of you. And if this is your project, then this is where the learning is supposed to occur. You could do it all in just Quartus (using either vhdl or verilog), or a combination of this and NIOS II software code running on the processor (compiled with the Quartus II tools )the hardware part).
Read lots of stuff on all of these Forums, and also on the NIOS II Forum's and good luck.
