15 years agoglobal pointer problem
Hi guys,
I am building a system with a NIOS2 core, a 128k on-chip ram, and a 128 SDRAM on DE2-115. Because I only want to use the SDRAM to be a storage space, I assigned .heap, .rodata, .rwdata, .stack and .text into the on-chip ram, and only assigned .bss to the sdram using the BSP editor. Then when I compiled the code, it complained: "warning: Unable to reach (null) (at 0x08000000) from the global pointer (at 0x07fec48c) because the offset (80756) is out of the allowed range, -32678 to 32767." The address assignments are: sdram: 0x08000000 - 0x0fffffff on-chip mem: 0x07fe0000 - 0x07ff3ff cpu: 0x10040800 - 0x10040fff jtag: 0x10041000 - 0x10041007 I found that if I put everything (.text, .rwdata etc.) into the SDRAM, then the program could compile. But this is against my goal to use SDRAM as a storage space only. I also found in the altera material that -G option may be used to disable the global pointer, but: 1.I don't know if it is the right way to do, or any side effect 2. I don't know how to apply this option, because I am only familiar with SBT infterface, not the command line tool...1 Reply
Just to update: The problem has been resolved. Basically, if one memory block is designed to be used as storage space only, then none of .heap, .rodata, .rwdata, .stack, .text and .bss should be assigned into that memory block. Because those are for program to run.
