18 years agoGlobal clock, virtual pins & incremental compilation
I'm doing an incremental compilation with a bottom up approach and I've a problem. The problem is that on a partition I've the clock management section and so their output go on other partition. ...
18 years agoSearch the Quartus handbook for virtual pins. You'll find a list of cases where you should not use a virtual-pin assignment. Clock inputs are one of those cases.
