15 years agoglitich in the outputs
i am getting some glitiched in the outputs, i am not sure what is the reason of then glitich and how to get rid of them, the glitichs happen in the output that are not changing
15 years agoyou dont want to slow the clock, you want to generate clock enables so that things only change when the enable is active. Dividing the clock (without a PLL, which wont work at low frequencies) will cause setup and hold violations.
