15 years agoglitich in the outputs
i am getting some glitiched in the outputs, i am not sure what is the reason of then glitich and how to get rid of them, the glitichs happen in the output that are not changing
15 years agoTHANK YOU FOR THE REPLY,, according to the codes you have seen already, as i am downloading these codes to the FPGA , and the changes of LEDs need to be slow to be recognized by human vision, and the board has 50Mhz CLOCK, how to add some codes to the existing codes to divide the clcok rather than using manual bushbutton as clcok, so i can use the internal clock of the FPGA,,
thank you so much
