15 years agoglitich in the outputs
i am getting some glitiched in the outputs, i am not sure what is the reason of then glitich and how to get rid of them, the glitichs happen in the output that are not changing
15 years agoyes you are right, i did compile the wrong codes, now everything is ok no more glitches, they are disappeared after the outputs are registred.
there is one thing if you could help me in dowing it,as i encoded my machine as gray coded , my current states are changing by numbers , i hope if i can make my current states change by the names i defined them in the enumration type, you can see that from the attached file
