15 years agoglitich in the outputs
i am getting some glitiched in the outputs, i am not sure what is the reason of then glitich and how to get rid of them, the glitichs happen in the output that are not changing
15 years agothank you for the reply, you mean i should use a register for the output, i have 2 process the first one is for current state process( synchronous process) which is clocked process to detrmine the current state while the second process is for Next State and output Logic Process (combinational process) that does not have clcok ,
so what u mean , you want to make registered process for the output , so clock should be used as it is registred or what you mean exactely
