15 years agoglitich in the outputs
i am getting some glitiched in the outputs, i am not sure what is the reason of then glitich and how to get rid of them, the glitichs happen in the output that are not changing
15 years agoAre you driving the output from a combinatorial block? When the inputs to a combinatorial block change, the data propagates through the block and can cause glitches on the output prior to settling.
You can either inforce state mapping on your input to prevent this or put a register on the output. Creating state mappings and custom logic to prevent glitches doesn't always work because Quartus tends to optimize them out. Registering the output always works but you have to have a clock in your design and the output will be one clock cycle late.
