CHess4
7 years agoGetting started resources for MAX 7000
Hi, I am starting to develop with CPLDs, and when looking for basic MAX 7000 circuits, I don't find anything on the net. Is there a sample basic circuit for integrating a MAX 7000A into a schematic...
CHess4
7 years agoHi, thank you, there are no schematics in that document. Where can I find sample schematics with power supply and in circuit programmability, ideally by a microcontroller?
ak6dn
7 years agoWell the datasheet has all the info you need. It lists the VCC and GND pins and the VCC power supply requirements (ie, 3.3V +/- 10%). Programming is via JTAG pins TCK, TMS, TDI, TDO which would connect to GPIO pins on a microcontroller and/or a connector for use with an Altera ByteBlaster programming adapter. All the other I/Os are 5V tolerant and connect to whatever devices you want. I don't know what else a schematic could show you?
