14 years agoget_cells usage
I am having problemunderstanding the get_cells command usage and results in Altera ( I am familar with the command in Primetime)
When I run this I get... query_collection [get_cells ] Info: Returned collection objects are limited by the default setting limit, 20 clk_sys WideOr0~0 pll_lock_mux~0 rtl~0 rtl~16 rtl~17 rtl~18 rtl~19 rtl~20 rtl~21 rtl~22 LEDOUT_GRN~0_wirecell LEDOUT_GRN~1_wirecell ~QUARTUS_CREATED_GND~I altera_internal_jtag XAUI_TX[0]~output XAUI_TX[1]~output XAUI_TX[2]~output XAUI_TX[3]~output LEDOUT_GRN[0]~output They dont look like fpga top cells to me but wires and maybe pins. ARe wires and pins considered cells to Altera? Also when I run this I get.... foreach_in_collection asgn [get_cells *] { puts $asgn> } cell_43578 cell_44306 cell_45282 cell_59634 cell_59636 cell_59638 Why is the result different?1 Reply
Those are cells. If you find them in the Chip Planner, they will be LUTs, FFs, and they will have pins on them. I'm guessing for the latter question, you need to run get_cell_info on each one. query_collection is probably assuming you want the name.
