13 years agoGenerating a signal with noise
What i am doing is i am trying to do is add random numbers to a signal to find PSD later. I wrote a code for random numbers generator which is working fine shown below: LIBRARY ieee; USE ie...
13 years ago --- Quote Start --- What i am trying to to do is to generate auto regressive process. --- Quote End --- I have not designed this type of system before, however, briefly reading this entry http://en.wikipedia.org/wiki/autoregressive_model It might be possible to implement this type of system using an Infinite Impulse Response (IIR) filter. You'll have to do a little more research to see if that is true. Cheers, Dave
