15 years agoGenerate Simulation data from RAM or ROM table and acquire with Signal Tap Analyzer?
I've designed a filter in matlab and generated HDL code and a test bench for this filter and successfully simulated this design in modelsim. i'm trying to verify the results by Programming the desi...
15 years agoTest benches are, usually, not synthesizable...
I assume your filter's input is a N bit vector which provides 1 sample per clock. If you want to run the test with L samples, you need a NxL ROM with the samples (you can use a megafunction for that). Then you need to connect the ROM's output to your filter's input and add a counter to cycle through the ROM's addresses.b You can then use SignalTap to see the filter's output.
