10 years agoFT232RL as a clock for a Acex EP1K50TC144-3 fpga
Hi, This is my first post on the Altera forum :) I don't know if there is someone who has knowledge using an "old" Acex EP1K50TC144-3 fpga. I'm using a FT232RL chip which is capable o...
10 years agoWhy do you need the pull-up? CBUS4 contains a complete buffer and shouldn't need any external pull-up. The 560R you mention could well be loading the signal such that it's shape changes. Have you tried removing it?
You're certainly right to take it into a dedicated clock pin. This shouldn't load the CBUS4 buffer unduly. I assume you don't have anything else loading this net? And you're powering the bank that the dedicated clock pin resides in at 3.3V? Happy New Year, Alex
