10 years agoFT2232H in Sync FIFO Mode - TXE# stuck high
hi, I have a Moprh-IC-II board and I'm trying to communicate via USB with a FT2232H in Sync FIFO Mode and D2XX Drivers. I manage to have the 60MHz clock input (my main fpga clock) from the...
10 years agoI'm using approximately the same, just trying with smaller buffers (64 bytes) to have something working first.
Do you know when your TXE# goes low, after which step ? Because mine is low at the beginning, goes high when the mode is set to sync fifo, and then never goes low, no matter what I'm doing. Alexis.
