10 years agoFT2232H in Sync FIFO Mode - TXE# stuck high
hi, I have a Moprh-IC-II board and I'm trying to communicate via USB with a FT2232H in Sync FIFO Mode and D2XX Drivers. I manage to have the 60MHz clock input (my main fpga clock) from the...
10 years agoHi,
The EEPROM seems right, the Software part too, and I have tested on an other Morph-IC-II to be sure there is no short circuit or bad solder. I'm a bit lost again, I don't where to look or what to try anymore. Thank you again for your help and ideas. Alexis
