10 years agoFT2232H in Sync FIFO Mode - TXE# stuck high
hi, I have a Moprh-IC-II board and I'm trying to communicate via USB with a FT2232H in Sync FIFO Mode and D2XX Drivers. I manage to have the 60MHz clock input (my main fpga clock) from the...
10 years agoI can't say for sure, I've used the FT2232 many times and not had this problem. Have you checked the obvious, TXE# is connected to an FPGA input pin and not an output being driven high? Have you tried clearing the transmit buffer with FT_Clear()? Have you actually issued an FT_Read()? Does the FT_Read() come back with an error, timeout, etc? What is your host system/OS?
