15 years agofsm debuging
fsm debugging Hi I started to check the fsm on real time and got some strange behaviors. I tried working with SignalTap but I didn't like the way he display the waves and we didn't really get ho...
15 years agohelo again,
I think I found the reason why the robot didn't responed to the commands Can I inside a component create a constant and caculate its value from generics constans like this: generic ( DC: time:= 17 ms; clock_period: time:= 20 ns; max_pulse: time:= 1 ms; min_pulse: time:= 2 ms; ); constant duty_cycle: integer:= DC/clock_period; --850000 constant min_cycle: integer:= min_pulse/clock_period; --50000 constant max_cycle: integer:= max_pulse/clock_period; -- 100000 constant neutral_cycle: integer:= neutral_pulse/clock_period ; --75000 and then ask if (Counter = duty_cycle) then I think I can't and that the value of the constant duty_cycle is zero thougts?
